2000 SS cranks awhile before starting
Just recently got a 2000 SS 6mt convertible 88k miles. This morning it cranked and cranked and cranked before finally starting. Stopped at gas station and it fired right back up, but then leaving work 10 hours later it did the same thing crank... crank... crank... then fire. I'm thinking it is fuel related like it isn't getting any fuel pressure?? I'm a nOOb when it comes to the modern electronics of the LS1 motor, so any help is greatly appreciated guys.
Sounds like the fuel pressure is not holding after the engine is turned off. Try priming the system by turning the key On & Off several times before actually attempting to start. If then starts OK, then it is a good sign that the pressure is not holding. Could be a bad pump, bad pressure regulator, or even an external fuel leak.
