2000 Camaro Help.
Old Jun 24, 2011 | 06:10 PM
KingScissom's Avatar
Default 2000 Camaro Help.
Hello, As you can see I am new to the site, and I have a question I would like to hopefully get some help with.
I have a 2000 Chevy Camaro, V-6 and it is a 5-speed. My car was not getting all of the power as it normally should. So, I went down and was informed that it was the EGR valve. Instead of buying a new EGR Valve, I went home, and took it off and cleaned it. I put it back on after I cleaned it, and it was not even dirty. I went for a test drive to see if that had cured my problem, but it had not. So, I went back and had it tested again. The guy at the parts store told me " Just drive the hell out of it," and at this time I knew not too. When I get up to around 45 mph, it just starts jerking. If it is not the Valve, does anyone have any helpful tips on where I may go from here. Thank You in Advance, Scissom
Old Jun 24, 2011 | 06:18 PM
libertyforall1776's Avatar
SES Light? If so get it scanned, what codes do you have?
Old Jun 24, 2011 | 06:34 PM
The only like I have on is my check engine.
Old Jun 24, 2011 | 06:35 PM
I was at Auto Zone first, and the guy told me that my collant was low and if I added some than it would fix my problem. I have had a day of bad information.
Old Jun 24, 2011 | 08:23 PM
Check Engine = SES -- what are you codes? Many auto part stores will scan it for free.
coopdc78
LS Series Tech
Jun 19, 2010 12:28 PM
hermine2000
2010+ V6 Tech
Mar 22, 2010 02:56 PM
TwistedEdge
Oct 2, 2008 02:00 PM
Mx35foxracing
VS
19
Dec 3, 2007 10:19 PM
chevy_man
Jun 25, 2007 08:56 PM
