2000 Aftermarket Remote starter?
I need to remove the aftermarket Remote starter on my 2000 Z28. I was told it was aftermarket but I have no clue on where I can find the hardware or the wiring that was done.
The fricken thing is randomly starting on me. As someone that works on his own car that can be pretty scary.
wow that is weird ,I had some that worked great on other cars ,check under glove box seats ,there should be part under the dash at some point its hooked to the ignition,not exacly sure ,must be a bad sencor there should be something mabey fuse in the box under the hood you can take out to stop it from working ,I have heard of it though an mabey a spot near the battery extra wires check both fuse boxes,kinda like looking for the right wires to cut on the bomb.but I think if you can find a fuse ,that will disable it,if it not maked try any odd looking fuse until it does not work
most of it should be by the column under the cover. at least thats where the one i had was. i just traced all the wires and took them out, hooked/taped up the wires and good to go.
