95 camaro 406 |
08-04-2015 12:11 PM |
wow that is weird ,I had some that worked great on other cars ,check under glove box seats ,there should be part under the dash at some point its hooked to the ignition,not exacly sure ,must be a bad sencor there should be something mabey fuse in the box under the hood you can take out to stop it from working ,I have heard of it though an mabey a spot near the battery extra wires check both fuse boxes,kinda like looking for the right wires to cut on the bomb.but I think if you can find a fuse ,that will disable it,if it not maked try any odd looking fuse until it does not work
