2/3 series carriers
Old Sep 26, 2007 | 06:54 PM
JHL88's Avatar
Default 2/3 series carriers
i have 2.73's on my 98z andiknow that 3.08's and below are 2 series and 3.23's and higher are 3's. someone told me it wouldnt work changing my 2.73's to 3.42's without changing the carrier but i found this: http://store.summitracing.com/partde...p;autoview=skuis this right?
Old Sep 26, 2007 | 07:15 PM
blackz87's Avatar
Default RE: 2/3 series carriers
ORIGINAL: JHL88
Yes, you can use these gear sets made for a 2-series carrier or a gear spacer which is wealer. Also, beware of Richmond gears for they are cut different and are not as quite as the stock gear sets. The cost of parts & labor for a gear change is going to be in the $500/600 range.
Old Sep 26, 2007 | 08:41 PM
JHL88's Avatar
ight sweet what other brand would you recommend?
Old Oct 2, 2007 | 11:15 AM
chrismorales75's Avatar
Why don't you look for a rear end from a wreched car that already has 3.42's? It might be cheaper and if you are going to 3.42's in a 98 why not run a 3.73 or 4.10? If you have an auto I'd run a 3.73, with a manual trand 4.10's for the best performance. PS just so you know the higher the ratio the weaker the gear will be and will be more likely to chip or break teeth.
Curt705900
15
Feb 4, 2013 01:34 PM
SinCity-7T4
Oct 25, 2011 04:56 PM
Bandit 43
May 28, 2011 12:05 AM
chevy2race18
Jan 10, 2009 07:38 PM
