1998 Camaro Wipers issue
Old Feb 3, 2010 | 07:46 PM
1998SilverMaro's Avatar
Default 1998 Camaro Wipers issue
Hi i have a 1998 3.8L camaro. When i turn on the windsheild wipers they dont do anything at all. But when i push the handle so it sprays the windsheild and the wipers come on they work. What should i do and where should i start? I also notice the yellow button for the rear hatch doesent work also should i check my fuse box?
Old Feb 3, 2010 | 08:16 PM
osduck5's Avatar
The fuses would be a good place to start. If you have good fuses, then check the switch for the wipers and the pushbutton for the hatch release. Should be able to ohm out the switch to the hatch but not sure about the wiper switch. Might have to take the steering column apart to locate the connectors for it.
Old Feb 3, 2010 | 09:17 PM
wiper switch should be in the blinker handle. did they suddenly stop working?
Old Feb 3, 2010 | 09:36 PM
well i bough the car about 2 weeks ago. this is the first time ive noticed them not working but im not sure when they quit. i called a dealership and they said somthing about a wiper motor trans comming apart. if i took the cowl out and took the motor out and put a light tester to it i should get power when the switch in the colum is turned on? and if i dont get power than i know its the switch i really hate taking about the colum
Old Feb 3, 2010 | 10:07 PM
to change the switch u change the blinker handle, at least thats were mine is. easy to change. wiper motor is under the hood up in a cubby hole behind the driver side hood hinge. pita. this is from my 93 book
Old Feb 4, 2010 | 09:18 AM
DrQuincy's Avatar
On a related note, has anyone ever encountered the wipers failing to fully retract when switched off? My wipers suddenly remain in the position they should only be in between delay swipes and do not retract when I switch them off.
Old Feb 4, 2010 | 09:47 AM
yes i have and its in the circuit board in the cover ***. i think u can get just the cover assembly but if your going to pull it apart and go threw the hassle u may want to change the complete wiper motor assembly. thats what i did.
flowride
Apr 2, 2013 01:26 PM
keithskye
Jun 29, 2012 08:56 PM
xlowes
Jul 24, 2011 05:22 AM
70Camaro&57chevy
70-81 V8 Tech
Dec 21, 2009 04:40 PM
heyjamai
Oct 22, 2007 08:24 PM
