1998 camaro 3.8 4l60e to manual t5 swap
Old Dec 27, 2015 | 03:33 PM
wwejj0926's Avatar
Default 1998 camaro 3.8 4l60e to manual t5 swap
Hello I have almost gotten every thing I need to finish my 1998 3.8 camaro 4l60e to manual t5 swap. My only problem is the wiring harness. The manual tranny that I'm installing came from a 1997 3.8 camaro.
1.) First, there is some kind of lever that was coming from the tranny to the the steering wheel switch. Is there anything I need to modify in changing the auto to manual switch? or can I just remove the lever?
2.) Secondly, there is two extra wiring connectors mounted to the pedal assembly for the clutch pedal. Is there any way I could add the connectors into the auto? For example would I need to ground and run it through a fuse so that the pcm can read it without popping off a code?
3.) Finally, the whole wiring harness that comes from the pcm that goes into the transmission has different connectors. Is there any way I could cut some wires and splice the tranny connectors so that they will fit into the manual? And will the pcm read it correctly without popping off codes?
I bought the pcm from the manual 97 camaro so I will be changing that.
EOWS 612
Jun 3, 2012 09:51 AM
doless
Oct 25, 2009 05:29 PM
andersonSLPZ28
Jun 30, 2009 04:40 PM
randolphdelpriore
Dec 13, 2008 07:10 PM
z28pete
Jul 5, 2007 01:27 PM
