1997 Camaro LT1 - New Fuel pump hissing help
Old Apr 28, 2011 | 11:16 AM
Hazard29's Avatar
Default 1997 Camaro LT1 - New Fuel pump hissing help
I recently had a fuel pump replaced at a garage and they used a Spectra Fuel Pump that I believe they purchased from Napa Auto Parts.
The application is:
1997 Camaro - 5.7 LT1
The car runs better with the new fuel pump however, this new pump seems very loud. When you turn the car over, you can hear a very loud hissing noise coming from the rear of the car. Is this normal? The factory pump was never loud and even though the car is running better with the new pump, I need to make sure they installed it correctly or that the pump is not faulty.
Can anyone shed some light on this issue?
Old Apr 28, 2011 | 06:16 PM
RFxCamaro's Avatar
I usually hear mine hiss for 5 secs on my 3.8. Not with car on doh. I'm sure somebody with a z will shed some light in a min but sounds normal to me.
Old Apr 28, 2011 | 06:34 PM
it should not be making much of a noise. have you told/asked the guys at the shop about it?
Old Apr 28, 2011 | 08:43 PM
I had my Airtex installed about a day when it got loud. I stopped by the part store and let them hear it. They offered to give me a new one. Two installs later I got a good one. 6 months later it is still quite.
Old Apr 28, 2011 | 08:49 PM
Hazard29's Avatar
The car seems to be running ok and I really don't want to drop the gas tank again or have the shop drop it again if I don't need to.
It seems to get quiter after I drive it for a bit but when I first turn it over - its kinda loud. It was a whole new assembly as well, sending unit plus fump that was changed.
Not sure if this Spectra brand is any good but thats what they said they put in there. They told me the airtex one looked like junk, something about the clamps and it being plastic....not sure.
Old Apr 28, 2011 | 08:56 PM
Noisy pump don't last long. These are hi reving pumps and noise = vibration and vibration = a short life. Hopfully it will louder before it fails. You might want to search the fuel pump hatch options. Saved me a ton of time now I can swap a pump in about 30 minutes.
Old Apr 29, 2011 | 05:33 AM
H2C's Avatar
H2C
Oh god thanks for scaring me guys, my airtex 3.8 is loud as heck. Guess ill call in the warranty, also the hatch method is soooooooooo good
Old May 24, 2011 | 07:28 PM
androzer's Avatar
i changed my fuel pump
when car gets hot i turn it of and restart it the pump sounds a little loud
and as much as the tank is empty the louder the sound. i hope its not going to die while i am driving so i have to ,,,,,,,,,,,,,,,. is it going?
Old May 24, 2011 | 10:04 PM
H2C's Avatar
H2C
My pump died again, 1 month this crappy airtex lasted, im saving and buying a high flow aftermarket one. recommendations?
Old Dec 11, 2014 | 08:04 PM
herrd's Avatar
Smile noisy fuel pump
Just bought a 99.fuel pump is real loud thanks for the hatch info
thatkidsanti
Oct 16, 2012 03:22 PM
Hazard29
Jun 16, 2011 02:53 PM
Hazard29
Apr 28, 2011 02:47 PM
QUICKB4C
Jun 29, 2009 09:34 AM
SANBOMBAZO
Jun 17, 2009 10:17 AM
