1995 t top
Old Jan 20, 2016 | 05:51 PM
BeasyNC's Avatar
Default 1995 t top
Hey guys n gals, I found out in the snow tonight, after I locked my keys in my car, that you cannot push the unlock lock buttons or yank the handle from the outside, and subsequently almost broke my driver window getting a t top off,is there a way to disable this feature?
Old Jan 21, 2016 | 02:06 PM
95 camaro 406's Avatar
better get a silm jim ,keep it in the car
Old Jan 21, 2016 | 09:30 PM
GaryDoug's Avatar
How would that help if the car is locked with the keys inside?
Hide a spare door key somewhere.
Disabling the 10 minute timer on the Retained Accessory Power feature would allow thieves to steal the car more easily and could run down the battery. You could just wire the door locks to an always hot wire instead of the RAP module.
Old Feb 3, 2016 | 06:31 PM
BeasyNC's Avatar
Lolol, I like your style
Old Feb 3, 2016 | 06:38 PM
BeasyNC's Avatar
It would help Becsuse then I can easily access the button on the inside with my "tool" which is cheaper and easier than spending 200 on a new key right now, I see what your saying, I guess I'll just look at wiring diagrams, thanks
Old Feb 5, 2016 | 11:17 AM
you can pick up a blank key on the net and have it cut at your local hardware, cost is like 10 bucks. just need to know the ohms on the key bean http://mysecuritypro.com/GeneralMoto...KeyBlanks.aspx
Old Feb 13, 2016 | 06:16 PM
Everett#2390's Avatar
Slim Jim isn't going to help you - too flimsy and no lock button to pull up You wouldn't want to keep it inside the Camaro - what good is it going to be when the Camaro is locked? Just sayin'...
You can get a key made - is it not the door lock and hatch lock the same?
And store the key in a magnetic key box and attach to rear wheel well out of sight or to the tank fill up tube. It will never fall off.
Or duct tape it behind the front bumper cover.
Old Feb 13, 2016 | 08:50 PM
A GM door key should be about the cheapest key on the rack at you local hardware store. The ignition from the dealer is pricey.
Andibo
Sep 23, 2013 04:20 PM
Devin's camaro
Feb 23, 2011 10:11 AM
Trollsmeesh
Apr 7, 2010 02:31 AM
s95droptopz28
May 29, 2009 07:17 AM
chadscamaro
May 21, 2004 07:57 PM
