1995 LT1 fresh build won't stay running.
Old Oct 15, 2021 | 04:42 PM
Thegamernerdguy's Avatar
Default 1995 LT1 fresh build won't stay running.
Every sensor and plug and everything is brand new.
It starts and runs for a couple seconds then dies. I do not have the oxygen sensors hooked up and I haven't replaced the fuel pressure regulator or the knock sensor. Could it be any of those? Amy suggestions. Like I said its a fresh build and it's not wanting to stay running and all sensors besides stated are new.
Also, it will not take throttle and if you try to give it throttle it dies and backfires.
Old Oct 15, 2021 | 06:51 PM
get them 02 sensors hooked up. test the fuel pressure, check to see if security light is on or blinking. scan it for trouble codes if you can.
Old Oct 15, 2021 | 07:06 PM
I plan on hooking the sensors up tomorrow, I had to retire retire because of previous owners doings. As for the security light it is not blinking or on I believe. As for fuel pressure I've got to pick up a gauge to test it. But would the oxygen sensors cause it to not run at all? I understand it will run too rich if they're not hooked up but not running at all?
Old Oct 15, 2021 | 11:32 PM
should run and have a trouble code or three.
Old Oct 16, 2021 | 06:43 AM
yeah it doesn't want to stay running at all. It will idle for a couple seconds and backfire if you give it gas then die. I'm going to check the fuel pressure regulator today and check the fuel pump.
Old Oct 16, 2021 | 09:45 AM
how old is opti? how old plug wires? double triple check plug wires to make sure they is in the right places. also make sure coil wire is all the way in. also may have gotten the opti in wrong, splined shaft can mess a guy up.
Old Oct 17, 2021 | 03:56 PM
everything is brand new. Not even a month old. Plugs are correct and yes the opti is in properly.
numskull223
Oct 21, 2011 12:55 AM
numskull223
Sep 25, 2011 10:07 PM
draggo144
82-92 V8 Tech
Nov 15, 2008 06:42 PM
FunkyColdMedina
Nov 12, 2007 10:23 PM
Camaro_dudeZ28
Mar 7, 2007 02:54 PM
