1994 scan code numbers
Old Aug 25, 2024 | 05:20 AM
Daddyracer56's Avatar
Default 1994 scan code numbers
hi our 1994 Z28 we just brought is not running very good at all she' sounds and feels like a 5 cylinder V8 and vibrates because of it , looking at sending her down to the local mechanic,s i know here in Sydney Australia they have had late 1960's Camaro's for over 35 years , said he can put a scan tool tester on her , i thought i found the scan numbers on here for the optispark fault codes ,not sure i have the right numbers off here , i have codes 12, ,36, 42, can somebody confirm if i have these numbers correct , im a old Harley Davidson mechanic and racer but not good with modern electronic tech , any help would be great thank you
Old Aug 26, 2024 | 02:54 AM
looks like 16 36 41 42 http://shbox.com/1/Dtcs.htm
Old Aug 26, 2024 | 10:33 AM
Agg Opti,, don't worry about code 12. That just means the engine is not running. I think it is "no reference ignition signal" Since codes are taken with the motor off, code 12 is in all cars.
Old Aug 27, 2024 | 05:29 AM
i wanna thanks for your help again , Bob,
Buchananr
Feb 12, 2019 06:27 PM
Bdmyles20
Feb 5, 2019 09:15 AM
Pierre Printitude
Jan 31, 2018 02:27 PM
Cliff Claven
Feb 4, 2010 09:56 PM
mike81
Dec 16, 2008 08:16 PM
