1994 camaro help needed ASAP!!
Old 07-29-2017, 12:43 PM
Originally Posted by Starquan
well the motor is an Ls3 that came out of my fathers short bed chevy truck he built so when he heard about my project he said the motor could work for that car. Since he is interested in another project now And no the car isn't overheating at all.and you right that's why I'm trying to figure this out before swapping the motor and trans for that exact reason of causing a cause and effect of problems, I'd rather figure this out if I can then fix this issue and then start the swap process. And again you are right I do have A LOT to learn so I figured better now than later since this will be my first self project, I know it won't be cheap or done perfectly the first time around but it's called a project for a reason so I joined this and a few other forums to start this learning process.
That is a HUGE project and it will be very technical. The PCM in your 1994 is not compatible with the PCM used on the LS3 motor. also the engine will not bolt in or even fit under the hood. That is a massive project for a speed shop with a fabricator and a professional tuner to get everything working. Getting the engine running will not be too hard but getting the rest of the 1994 electronic to work with 2008 tech is going to be a stretch. That LS3 is worth more then a low miles LS1 SS camaro.
You would be much better off finding a LS1 4th gen to swap the LS3 into. At least then the engine would bolt into place, you will just need a different hood. You still going to need to deal with electronic, even more so with the 98-02 tech. If you are serious about the swap forget what I said about figuring the old issue out. There will be no interchangeable parts off a LT1 that will work with a LS3. Fixing the LT1 is just a waste of time.
x01660
06-08-2011 05:01 PM
CamaroSpeedRacer
06-11-2006 02:17 AM
jamesdean64
06-25-2005 02:27 PM
Mr_Chu
05-14-2005 06:59 AM
Quick Reply: 1994 camaro help needed ASAP!!
