1994 camaro help needed ASAP!!
Hey wassup guys, I need help with my 1994 camaro. Ok so for some reason my car will crank and run perfectly fine but when I get up to 55mph then the check engine light comes on and it shuts off. Now my car is currently located in Florida and the problem is I have to drive it back home to New York to where I currently live now so averaging 50-53mph will be a headache. If not a major problem I would like to get help on how to fix it before I have to get it and drive it back as it is now.....
Does the light just come on or does it flash,,, The symptoms you are describing are not common. I don't think I have ever heard them before.
Getting the PCM code is critical. I assume that once you restart the car the light is off?
When it shuts off is it like someone turned it off or does it fight to stay running giving you a second or two warning?
Fighting to stay running would sound like a fuel issue, cutting off instantly would be an electronic issue. I would have no idea what speed would have to do with the fuel system. To shut the car off instantly you are talking an ignition system failure but that would not set a check engine light. Except maybe random misfire?
The only problem with that is that when I turn the car back on the check engine light is off, it only cuts on once I hit over 55mph.
ok I didn't know that it saves the code so ok cool I'll try that but let me ask y'all this, I already planned to swap out the motor and trans anyway once I got it back home. What's the possibility that swapping both would fix this issue? Because I already have the new motor for it, just don't have it swapped out yet due to my concerns about this current issue.
That depends what are you swapping. A Short block or a Long block a used engine with all the sensors (it would need to a similar year engine).
This does not sound like a mechanical engine failure unless the car is over heating. Over heating a high speed sounds backwards. Normally higher speeds cool the car off faster unless the thermostat is stuck. A stuck thermostat would over heat idling but it may take a few minutes longer.
I would defiantly figure this out before I put in the new motor. This could be plugged Cat or a sensor, PCM itself or the fuel system. A used engine from the same years with all its sensor may fix the issue but that is a complete roll of the dice plus you are adding variables. Especially if the issue is being caused by a combination of issue and you fix one but make a mistake during the swap.
Someone that does not know PCM codes are is going to do full drive train swap in a PCM controlled car. Sounds like you have a LOT of learning ahead of you.
This does not sound like a mechanical engine failure unless the car is over heating. Over heating a high speed sounds backwards. Normally higher speeds cool the car off faster unless the thermostat is stuck. Astuck thermostat would over heat idling but it may take a few minutes longer.
