02 z28 weird intermittent no start problem
Old Feb 22, 2015 | 07:25 PM
lightningcruiser's Avatar
Default 02 z28 weird intermittent no start problem
i'm hoping someone has had this issue previously and can shed some light on the issue. last night, i went out to my car to start it after work, and when i inserted the key, it dinged like it usually did, but when i turned the key to start it, it died. no lights, no crank, no nothing. i used a jumper pack to jump it and it started. i went out to start the car this morning and it started fine. it started again fine after that, but when i went to start it again to go home from work, same issue as before. but when i pulled the key out, the dome lights came on. so i put the key in slowly and turned it slowly and it started just fine. anyone have any idea where i should even start on this? possibly and ignition switch? vats issue? bcm? any help is appreciated. thanks everybody!
Old Feb 23, 2015 | 04:58 AM
sounds like vats may be acting up. try cleaning the key and spray some electrical cleaner in the key hole.
Old Feb 23, 2015 | 05:44 PM
Marvmc's Avatar
Have an 88 IROC with same problem and was the fuel pump check valve.
Old Feb 23, 2015 | 05:47 PM
Marvmc's Avatar
Sorry didn't read the whole post mine was a crank no start one time next start right up.
Old Feb 23, 2015 | 06:06 PM
i don't think it's the vats system. i drove the car today and when i parked it in my garage it just randomly shut off. also, vats wouldn't disable all of the power, it would still allow all of the lights to work, the car just wouldn't crank and the security light would flash.
Old Feb 24, 2015 | 06:35 AM
start by cleaning your battery terminals and cable ends. wire brush the heck outa them. may need to scrape them to get build up off. sometimes a layer of carbon can form and is hard to see. i had a issue like this and it was the ignition switch so you may want to look in that direction as well.
v64thgen
Jun 27, 2014 02:38 PM
Mikey.
Apr 14, 2012 11:40 PM
oomfh
Jul 4, 2011 08:17 PM
oomfh
Dec 15, 2010 10:16 AM
rgviola
Sep 20, 2005 05:01 PM
