02 Camaro AC only blowing hot air
Old Jul 21, 2013 | 01:58 PM
G2Jr's Avatar
Default 02 Camaro AC only blowing hot air
i replaced my ac compressor and took it the shop to get it charged and everything. it was working and blowing cold air for about a day and half and then i heard a "crank" and then just started blowing HOT air. Now it only blows hot air. when i pop the hood and feel the ac lines, they get cold like they should be but something isnt letting the air threw. i was told might be my blend doors?
Old Jul 22, 2013 | 07:26 PM
Massey's Avatar
Change settings on your heater and see if you get air through the different ports. Also once the engine is hot check that the temp comming through the ducts change as you change the temp setting.
Massey
jdobbs
May 10, 2011 06:59 PM
Lawhead09
Jul 1, 2010 02:54 PM
TJeep_1999
Jun 15, 2009 10:20 PM
Little_Richie
Jun 5, 2009 09:24 PM
