What does the Brown wire on the alt do
Old Feb 15, 2010 | 03:30 PM
1990z28tpi's Avatar
Default What does the Brown wire on the alt do
Well I am still haveing chargeing problems on my car was wondering where the brown wire on the alternator goes.. I know the alternater is good but still can not get it to charge.. Thanks Jesse P.S 1990 Z28 5.7 tpi
Old Feb 24, 2010 | 12:35 PM
bryan0609's Avatar
I was having the same problem on my iroc check to make sure you have power for your fuse box to your alt mine was the second fuse usaully a 20amp fuse but i drop all power to that slot and was not allowing mine to charge and if so you can run power back to that spot from a power acc i ended up replace the whole harness
Old Feb 25, 2010 | 04:38 PM
1990z28tpi's Avatar
Yea what I did was took the brown wire from the alt and hooked it to a another 12 volt source and bang it started charging...
Old Feb 26, 2010 | 08:16 AM
bryan0609's Avatar
yea so somewhere between you power acc off you ignition switch to your fuse box your droppin power
rs657f
Jan 9, 2015 08:13 PM
pyrofire127
Mar 6, 2008 11:57 PM
carl1000
Jun 18, 2007 10:37 AM
