Misfire
Old Feb 25, 2010 | 04:10 PM
bobblehead2205's Avatar
Default Misfire
Bought an 85 Z28 bout a week ago...ran well but started dieseling. We attempted to do the timing but ever since we moved the timing it feels like its missing...but ONLY at low rpms. I replaced the cap and rotor with a MSD one and replaced the plugs...any ideas?
Old Feb 25, 2010 | 05:17 PM
What procedure did you use to adjust the spark timing? There are many reasons for dieseling besides spark timing.
Old Feb 25, 2010 | 05:55 PM
Hmmmm....dieseling. You didn't put a train horn on your car too did you?
But seriously folks, a little more info may help. Do you still have FI or has it been converted to carb, stock cooling fan setup, etc.
Old Feb 25, 2010 | 07:32 PM
Carb 305, auto, everything is stock except the cap and rotor. And i used a timing light.
Old Feb 25, 2010 | 08:01 PM
Oh and i forgot to say that the misfire didnt start happening until we started changing the timing. And since we adjusted the timing when you get on the throttle its almost like the carb is flooding...and i cant find any carb adjustment screws...
Old Feb 25, 2010 | 09:24 PM
What kind of carb? And where did you set the timing at.
Old Feb 25, 2010 | 10:25 PM
Thats the thing...i dont know exactly which carb. I know it has a Rochester Quardrajet on it...but i cant find the model on it. And we set the timing at 5 btdc but then had to change it cuz it ran like crap and we advanced it by ear so not sure. Chiltons says it is supposed to be set at 6 btdc so i tried to set it at that but it didnt seem to run even close to right so had to do it by ear again.
Old Feb 26, 2010 | 08:48 AM
Look under the hood and see if you have a tune up procedure label. If your engine has the electronic spark timing (EST), you need to disconnect it before setting the timing. Look for a long plug with a tan wire/black stripe that comes out of the fat wiring harness, and is located on the passenger side between the firewall and strut tower. Disconnect the plug, set the timing, then reconnect it.
samkopyna
Sep 5, 2012 10:41 AM
leonard1
Oct 23, 2011 10:41 AM
steveh3500
Feb 18, 2010 01:56 PM
dumbnstupidone
Jan 21, 2008 08:40 PM
NasteeZ
Oct 31, 2007 09:55 AM
