Valve guide smoke
Old Mar 18, 2010 | 11:16 AM
washtubman's Avatar
Default Valve guide smoke
I have the "infamous puff" of blue smoke when I start my 5.7 after it sits a couple hours; drives me crazy! No other problems with it. Anyone recently replaced valve guide seals in a 5.7, and if so, approximately what did it cost to do it?
A friend of mine said you can buy "smokeless" oil and that he has used it in some of his older Corvettes. It is quite expensive (17.00 a Qt.), but I was wondering if anyone else out there might be able to give testimonial to it. Thanks.
Old Mar 18, 2010 | 11:26 AM
Jr. Mechanic's Avatar
August 2009 ROTM
Any oil advertised as "smokeless" is going to be nothing better than snake oil.
Replacing the valve seals is a pretty straight forward job. It can be done with the heads on the engine, but you will need a large air compressor, spark plug adapter, and a puller for use with the heads attached. Start with the #1 cylinder at TDC on the compression stroke. Remove the spark plug and pressurize the cylinder with compressed air. Remove the valve springs on the #1 cylinder, replace the seals, reassemble the springs, and move on to the next cylinder following the proper firing order.
MusicMan
Nov 29, 2012 10:02 PM
nerfsmurf
Jan 26, 2011 04:18 AM
evilkal
Jul 21, 2009 12:09 PM
Mesosneaky
Jun 9, 2009 03:03 PM
