V6 to v8 questions
Old Jan 9, 2010 | 07:50 PM
Cblaze's Avatar
Default V6 to v8 questions
I know i gotta change the coil springs .what about the sway bars is there any difference between v6 and v8 ones.read some where i need to change the one on front.also wondering bout the energy suspension polyurthane bushing kits these good as they say and worth the trouble?
Old Jan 9, 2010 | 08:38 PM
if your going to have it apart new bushings would be good. not sure on the sway bars and if u want it to set a bit lower leave the stock spring in it. just as hard to change with either motor in it so why not see if u like it. lol.
Old Jan 9, 2010 | 08:48 PM
Cblaze's Avatar
How much lower you thank it would set? already have problems pulling in some parking lots rubbing .
Old Jan 9, 2010 | 08:52 PM
oh,,, well then u should probly change em. how about a couple pictures?
Old Jan 9, 2010 | 10:06 PM
Cblaze's Avatar
aint got a computer im using my cell phone to get on here
Old Jan 10, 2010 | 12:13 AM
mighty mike's Avatar
sway bars are the same and to be honest u really dont have too to change the springs either. they will only be a liltte bouncy. i did but u really dont have too.
Old Jan 10, 2010 | 09:32 AM
Cblaze's Avatar
Originally Posted by mighty mike
sway bars are the same and to be honest u really dont have too to change the springs either. they will only be a liltte more softer. i did but u really dont have too.
compared to every thing else im gonna do on the car the springs aint much so i will probably just change them and install the polyurathene bushings.brakes should be good though shouldnt they? dont know if there is any difference.never heard it mentioned
Old Jan 10, 2010 | 09:15 PM
same.
Old May 21, 2010 | 08:56 AM
camaro cowboy's Avatar
if i understand right a 350 motor will bolt up to a transmison from a 2.8 motor if it dose what eles do i need to change
Old May 21, 2010 | 10:06 AM
depends on what tranny, is it a 2004r or 700r4? 700r4 will be ok. 200 4r is a weak trans. will not hold up for long.
