tranny leak questions!!!
Old Dec 13, 2009 | 10:50 AM
behindyou's Avatar
Default tranny leak questions!!!
tranny leak bad....not the pan coming from in front of torque converter any suggestions??? how much will it cost? and could i fix this myself or will the tranny have to come down?
Old Dec 13, 2009 | 11:09 AM
blackz87's Avatar
Front shaft seal. The transmission needs to be dropped for replacement. Estimate cost by a shop $300/400 range. Not a DIY type of job unless you have a lift and tools. I would not even think about doing this with jack stands, my opinion.
Old Dec 14, 2009 | 01:02 AM
mtn_maro's Avatar
do you say this just due to the difficulty of dropping the tranny because of the weight? cause i have dropped turbo 350 tranny's with the car on jack stands and and a floor jack. you just gotta be careful and go slow.
a tranny jack would have made things a lot easier tho. i would suggest at least getting one if you do decide to drop the tranny.
Old Dec 14, 2009 | 06:39 AM
blackz87's Avatar
"be careful and go slow" where have I heard that before???? I don't think any young guy is going to ahear to that advice. My opinion still stands, if you do not have the proper equipment for a major repair get it done by someone who has it.
Old Dec 14, 2009 | 03:10 PM
jencinas's Avatar
i had the same problem. look at your speed sensor. its located at the neck of the transmission. the seal on mine was done, therefore leaking like no ones business. it cost like $40 i wanna say. simple pop in and out. make sure that the speed sensor isnt leaking then do what the other guys said.
mac022705
Aug 27, 2010 09:28 AM
chevydrvr
Jun 14, 2010 09:44 PM
bobarian91
Nov 4, 2008 10:59 PM
92 RS in training
Jul 8, 2008 05:44 PM
ScottD
Aug 25, 2006 10:40 AM
