Temp sending unit
Old Aug 2, 2010 | 08:17 PM
baarf's Avatar
Default Temp sending unit
I am putting in a 350 into my 1983 Berlinetta
On the block, drivers side on the head, is a huge threaded hole for a temp sender, any idea what the part number might be?
Anyone out there with a 350 who might have replaced one recently?
It's huge, about 3/4 to 1 inch into the water jacket.
Old Aug 2, 2010 | 10:17 PM
Are you using the stock gauges? The sending unit needs to be compatible with the gauge. Don't worry about it fitting the head, you can use a reducer fitting (from the hardware store plumbing dept.) if the sending unit is smaller than the hole.
Old Aug 5, 2010 | 09:47 AM
baarf's Avatar
Thanks man!
Boy you know everything!
Now just tackle global warming.......
Old Aug 5, 2010 | 09:53 AM
91camaro350's Avatar
**** i think he can do that to he is the man
Old Aug 5, 2010 | 09:54 AM
baarf's Avatar
As long as we are on the subject, I am using an Edelbrock Performer intake, is there any reason I cannot move the temp sender to one of the ports on the intake?
That would get the wring away from the headers.
Old Aug 5, 2010 | 10:47 AM
The coolant in the intake manifold tends to run a little cooler than in the head.
Having the sending unit in the head will give you a more accurate reading.
Camaroforlife
Mar 27, 2014 08:26 AM
bayman88
70-81 V8 Tech
Apr 25, 2010 02:05 PM
kyleag89
Oct 5, 2008 12:18 AM
muscleman
Jul 11, 2007 08:14 PM
ohiocopper12
May 10, 2007 10:09 PM
