Temp sending unit
I am putting in a 350 into my 1983 Berlinetta
On the block, drivers side on the head, is a huge threaded hole for a temp sender, any idea what the part number might be? Anyone out there with a 350 who might have replaced one recently? It's huge, about 3/4 to 1 inch into the water jacket. |
Are you using the stock gauges? The sending unit needs to be compatible with the gauge. Don't worry about it fitting the head, you can use a reducer fitting (from the hardware store plumbing dept.) if the sending unit is smaller than the hole.
Thanks man!
Boy you know everything! Now just tackle global warming....... |
**** i think he can do that to he is the man
As long as we are on the subject, I am using an Edelbrock Performer intake, is there any reason I cannot move the temp sender to one of the ports on the intake?
That would get the wring away from the headers. |
Originally Posted by baarf
(Post 444861)
That would get the wring away from the headers. Having the sending unit in the head will give you a more accurate reading. |
