tach probs
Old Nov 24, 2008 | 09:37 AM
draggo144's Avatar
Default tach probs
I finally got my 91 305 tpi running and the rpm gauge is way higher then it really is. It says that it is around 2k to 2.5k when it is really around 1k to 1.5k. Any ideas how to fix this? Or which wires to tap into to put in a separate rpm gauge.
Old Nov 24, 2008 | 10:18 AM
Default RE: tach probs
Welcome to the club, my 91 reads about double too. With so many people having the same problem, I wonder if anybody has a 90-92 Camaro with a tach that works?
It appears that the problem is a bad resistor on the little circuit board inside the tach cluster. Here's the best info I've been able to find, just haven't had the time to try it on mine yet.
I'm still using the divide-by-two method!
90-92 Tach Fix
Old Nov 24, 2008 | 05:52 PM
MadMikeZ28's Avatar
Great! Juuuust Great!
Now that I read this its only a matter of time that mine does not read correctly.
Thanks guys! [:@]
Old Nov 24, 2008 | 06:25 PM
I just said a prayer for ya Mike, good luck!
Whooooops....I think with the way I worded it, it may have come out more like a hex!!!! Oh well, I tried.
Old Nov 24, 2008 | 06:50 PM
draggo144's Avatar
So how hard will it be to put on an aftermarket tach?
Old Nov 24, 2008 | 08:00 PM
MadMikeZ28's Avatar
ORIGINAL: Camaro 69
Heyyyyy!
Well as long as some one does not curse me and make my junk fall off.
Aftermarket tach is simple. Power when the key is on, power for the light, ground and a signal. I think the hard thing would be is to find a place you want to put it.
Old Nov 25, 2008 | 05:01 PM
ORIGINAL: MadMikeZ28
ORIGINAL: Camaro 69
Heyyyyy!
Well...here's how the prayer went:
Dear cargods, please look over MadMikeZ28, and try to save his needle from petering out.
I dunno man, I think you might be on your own!
Rhinohillman09
Mar 9, 2010 04:49 PM
ryan.doyle86
82-92 V8 Tech
Feb 1, 2010 02:54 PM
Berlinettaguy_84
May 19, 2009 03:36 PM
Rs Camaro Kid
Dec 3, 2006 01:59 AM
gtodave05
Nov 26, 2006 12:30 AM
