lock probs....still
Old Dec 2, 2006 | 11:52 PM
Rs Camaro Kid's Avatar
Default lock probs....still
My drivers side door wont unlcok from the outside when using then key what the hel-heck can i do to make it work
Old Dec 3, 2006 | 12:01 AM
MadMikeZ28's Avatar
Default RE: lock probs....still
Does it turn? possible a metal clip broke and the rod popped out. If it wont turn and you have power door locks the solenoid might be froze.
Old Dec 3, 2006 | 12:04 AM
no when i put the key in it doesnt turn at all
Old Dec 3, 2006 | 12:31 AM
and ya i do have power locks
Old Dec 3, 2006 | 01:14 AM
MadMikeZ28's Avatar
When you push the button does the solenoid move the lock? I have had to replace solenoids before because customers did not like having to enter through the passenger door......WUSSYS!
Old Dec 3, 2006 | 01:35 AM
ya the solanoid moves but i have to press the button about 5 or six times until it unlocks
Old Dec 3, 2006 | 01:39 AM
MadMikeZ28's Avatar
Its that way on my drivers door but only when the panel is on the door. Try pushing the button to unlock while turning the key. If the key still wont turnthen maybe a squirt or WD40 though the latch might loosen it up.
Old Dec 3, 2006 | 01:49 AM
i tried wd40 and it didnt work but ill have to try and push the button and turn the key at the same time
Old Dec 3, 2006 | 01:59 AM
MadMikeZ28's Avatar
When all fails then its time to pull the door panel off and check everything from the lock cylynder all the way to the inside handle.
ryan.doyle86
82-92 V8 Tech
Feb 1, 2010 02:54 PM
Berlinettaguy_84
May 19, 2009 03:36 PM
sm515
Apr 26, 2009 06:27 PM
gtodave05
Nov 26, 2006 12:30 AM
Rs Camaro Kid
Nov 6, 2006 01:42 AM
