fuel probs
Old Feb 1, 2010 | 01:04 PM
ryan.doyle86's Avatar
Default fuel probs
i have an 86 camaro and it was a v6 and i put a 327 in it and im having some problems with the fuel. i was wanting to know the best way to go with, if it was a fuel cell or electronic fuel pump or whatever. but if someone could tell me the best way thanks
Old Feb 1, 2010 | 01:48 PM
What problems are you having? Your v6 engine was fuel injected with an electric fuel pump in the tank. I'm guessing your 327 is carbureted? If all that was done was an out with the old and in with the new, then that can be your problem. You can't run the existing electric pump (if you are) without a pressure regulator before the carb. If the power to the electric pump was just unplugged and you now have a mechanical pump, then the non running in-tank pump will be restricting fuel flow.
Old Feb 1, 2010 | 01:54 PM
yes the 327 is carb and the v6 was injected and on the 327 i have a mechanic pump but. We left the pump in the tank so now we would have to take out the pump in the tank?
Old Feb 1, 2010 | 02:21 PM
That would be the best way, and then connect point "a" with point "b" where the pump was disconnected from. Or, you can use the electric pump if it still works, bypass the mechanical pump, and put in a regulator.
I've heard some say you could try blowing high pressure air into the fuel line with the hopes of blowing out the membrane of the electric pump. By doing that though, you take the chance of blowing out the connection between the sending unit and pump. If that happens, you won't be sucking gas from down low, and around half a tank or so will make you run dry.
Old Feb 1, 2010 | 02:54 PM
ok will try that but if any other probs ill be bak on
Rhinohillman09
Mar 9, 2010 04:49 PM
striderx
Aug 30, 2009 03:30 AM
Midnight Falcon
Jul 24, 2009 12:11 PM
ridgedrifter
May 10, 2009 05:18 AM
draggo144
82-92 V8 Tech
Nov 25, 2008 05:01 PM
