Somethins wrong with my 87 iroc
Old Mar 31, 2009 | 10:14 PM
a-dusty-camaro's Avatar
Default Somethins wrong with my 87 iroc
uhh well. Im stumped i dont know. I have a 87 Iroc z 305 with tuned port injection
Ive had it in the garage. tryin to figure out whats wrong.
It starts. but wants to die. I rev it to keep it alive but if you hold it it backfires so you gotta keep reving.
I had my friend time it he says he timed it perfect. I replaced Distributor cap, distributor and the rotor.
Im stumped idk. any ideas?
Ive recently put in a new battery and starter.
Old Mar 31, 2009 | 10:24 PM
mtn_maro's Avatar
check for codes?
Old Mar 31, 2009 | 10:31 PM
Well surprisingly the check engine light is not on. so i cant test that.
Old Mar 31, 2009 | 11:40 PM
Saint Ebony's Avatar
Third Generation Moderator
March 2010 ROTM
https://camaroforums.com/forum/82-92-v8-tech-13/something-wrong-my-87-iroc-z-36993/
Hmm.
Anyway, are you sure it's TPI? You've apparently replaced some parts it shouldn't even have to begin with.
Old Apr 1, 2009 | 12:44 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
I replied to that thread. I will fix the double and post in here too.
Is there a reason you replaced the entire dizzy?
I saw that too saint ebony..... I guess we will see huh?
Old Apr 1, 2009 | 06:25 AM
well i replaced the battery and starter because the starter was out and the battery had bad cells way before this problem happened.
To solve this problem, i timed it. Replaced the rotor, Distributor, distributor cap.
I gotta check injectors, vaccums, like the EGR valve
Old Apr 1, 2009 | 08:52 PM
age84's Avatar
March '09 ROTM
How many miles dose the motor have
Old Apr 2, 2009 | 07:14 AM
and im pretty sure it is a vaccum leak or broken hose.
so im doing that now and ill let you know how it went.
trippyz28
Mar 16, 2008 11:03 AM
Furr1970
Oct 30, 2007 01:35 AM
SpecterGT260
Oct 18, 2007 10:04 AM
92rscamaro
Oct 24, 2005 02:13 PM
