Not starting easy?
Old Jan 28, 2012 | 12:44 PM
Aaron Sisco's Avatar
Default Not starting easy?
My car isnt starting easy. It cranks slow then dies down makes a noise like it skips something.. Any suggestions?
Old Jan 30, 2012 | 08:02 AM
torque_is_good's Avatar
is the
"makes a noise like t skis something" more like a grinding noise?
If so, then it's a tooth on the flexplate
as for slwo cranking, it's probably the battery but could well be the starter
it never hurts to replace the cable to the starter either since you'll be down there
Old Feb 11, 2012 | 11:35 PM
Berlinetta's Avatar
Is your car carbureted? Check your CCA (Cold Crank Amp) rating and if it is cold outside aswell. Im not sure of your mechanical background, but go with easiest first!
Nofear1911
Mar 15, 2008 09:41 AM
BigNic
VS
41
Oct 18, 2007 08:18 PM
1Camaro1994
Feb 16, 2006 02:46 PM
