No heat! NEED HELP!!!
also while your at it check out this wire (i think it's purple) with a test light and see if it has power when you turn on the heater... it is the blower motor power wire so it should if not then there is more work to do if it does the the blower is bad (easy fix)
thank you so much guys. your really going above and beyond the call of duty got me and it is greatly appreciated. i found out that one of the hoses i thought was cut turns out to be some sort of equalizer on the passengers side on top of the head. i herd this from my brother who is more engine smart then i. i will be sure to keep you guys posted with my progress but unfortunately i was driving yesterday and my car just stopped out of the blue. upon testings it we have determined that my alternator is shot and im going to need a new batery. it doesnt look like im getting a spark from the coil pack either so im going to replace that too. not excited about the entire ordeal but it is what it is. but i will be sure to keep everyone posted with whats what. again thanks a million guys!
yeah, exactly power going in and no work = bad blower motor, so unfortunatly you'll have to replace it... fortunatly they are easy to change and aren't usually very expensive. depending on weather or not you have A/C they are between $20 and $30 here (illinois) at autozone.
