New Member with a question?
Old Feb 7, 2008 | 04:43 AM
zxjuiced's Avatar
Default New Member with a question?
Hello everyone, I just bought a 1987 Iroc-Z witha blown 305,engine has a spun cam bearing!
My question is: I was thinking either rebuild the 305 or buy a short block 350. Beings that Im new to TPI Engines if I was to swap in a complete TPI 350 or just use the short block 350 and the Top End off my 305, do I have to also change out the wiring harness and computer for a 350TPI Camaro??Or can I use thethe wiring harness and computer etc, from the 305?? thanks guys.............
ps. looking forward to being here as a proud new owner and member ofTHE THIRD GEN CAMARO FAMILY.
pss. I`ll post pics of the Iroc-Z soon!!
Old Feb 7, 2008 | 09:22 PM
jml317's Avatar
Default RE: New Member with a question?
personally i would just swape the top end over to a 350 block, at most auto shops you can get anew ecu computer that set for a 5.7 tpi, you may need to change some sensors in 87 they had 350tpi so its not hard to do. would deff recomend getting some heads for it, wouldnt put 305 heads on it.
Old Feb 8, 2008 | 07:44 AM
blackz87's Avatar
Everything external on your TPI 305 will transfer over to the 350 short block. Except you will need 22# fuel injectors, knock senor and new Prom for the ECM. Unless you want some newer parts that is about it. You are lucky you have the complete TPI system and the wiring harness hooks up the same as on your 305. Been there and done it.
[IMG]local://upfiles/2696/5B0CD2FE5EA34C56977DCA4055B95F5E.jpg[/IMG]
Old Feb 9, 2008 | 09:34 PM
zxjuiced's Avatar
ORIGINAL: blackz87
Thanks for the info! But what do you mean : I `ll have to get "new prom" for the computer?
Im not sure what your referring to...Thanks..
Old Feb 10, 2008 | 06:27 AM
blackz87's Avatar
ORIGINAL: zxjuiced
ORIGINAL: blackz87
Prom=Chip in the ECM (computer) for the 350.
I also for got about the heads you will need with the short block. 67cc 1.940/1.500 would work for you.
Old Feb 13, 2008 | 07:15 AM
zxjuiced's Avatar
ORIGINAL: blackz87
ORIGINAL: zxjuiced
ORIGINAL: blackz87
Thanks, sounds simply enough!
Dave K
Nov 4, 2013 07:12 PM
DarkFox
Jan 31, 2011 11:22 PM
goodbuck
Oct 22, 2010 07:37 AM
colez
Jul 13, 2010 03:07 PM
genvoodoo
Jan 15, 2008 12:48 PM
