motor and harness swap..Help!
Old Aug 22, 2010 | 11:15 AM
hawgranch's Avatar
Question motor and harness swap..Help!
I'm swapping a 305TPI and harness from a 88 IROC into a 85 IROC,and have noticed that there are some obvious differences.Also the 88 had a five-speed tranny(wich will also be going into my 85).So my question is do I have to swap out the dash wiring,or can I do it with my existing hardware?
Old Aug 22, 2010 | 07:35 PM
microkid's Avatar
March 2011 ROTM
Technical User
the gauge wiring should all be similar if not the same. the differences between those years were some minor engine changes and ecm changes. the only gauge difference came in 90 with the electronic speedo and new cluster design. otherwise it should all work. if not, you can always get aftermarket gauges
Old Aug 23, 2010 | 10:29 PM
hawgranch's Avatar
So by that note I should just be anle to swap the motor,harness,and computer with no problems?
Old Aug 24, 2010 | 07:19 PM
microkid's Avatar
March 2011 ROTM
Technical User
you should be able to. i have not done that before and cant say that it will be plug and play, but im rather sure all the gauge stuff will be the same since it was one v8 to another.
Old Aug 25, 2010 | 10:27 PM
hawgranch's Avatar
well I'm gonna try it.If it dont go I'll add the parts from the other car and cross the fingers and toes
amsteff
Nov 14, 2011 11:14 AM
sandvipr
Apr 25, 2011 12:03 PM
mregulater
82-92 V8 Tech
Mar 10, 2009 11:47 AM
jjmann
Jun 20, 2008 08:01 PM
crgm101
Nov 25, 2007 10:24 PM
