more powerful camaro z28 305 years 1992
Old 11-08-2009 | 05:15 PM
RED_CAMARO_V8's Avatar
Default more powerful camaro z28 305 years 1992
hello to everybody...im italian and i ve a chevrolet camaro z28 25°anniversary 305gm automatic gear..the engine have 205 hp,but would like to have more powerful so, i thought of looking for another engine more power,but i dont know which engine can i putting..would like a 350 with 300hp turn key..somebody can helping where see or to talking for know exacly what engine is right..thanks to alls
Old 11-08-2009 | 05:34 PM
Y2K's Avatar
Y2K
The 350 or a stroked 350/383 is a great choice.
They are the same physical dimensions on the outside as a 305 so will bolt right in and all accessories will hook right up in the factory positions.
Old 11-15-2009 | 09:41 AM
hello..thanks for answer me..of course you speak about a engine with carburator..right?? did you know some web page where see some engine turn key for my camaro..thank you
Old 11-15-2009 | 10:28 AM
Y2K's Avatar
Y2K
Either carb or fuel injection depending on what year car you have,a 350 replaces a 305 either way.
As for crate engines that are turn key there are many sources,not sure about international shipping but here's a few for you.
Summit has a wide variety.
http://www.summitracing.com/search/?...20engine&dds=1
So does Jegs.
http://www.jegs.com/webapp/wcs/store...atalogId=10002
http://www.customcrateengines.com/
http://www.enginefactory.com/
http://high-performance-engines.host..._Code=Category
http://www.gatorengines.com/
http://www.ultrastreet.net/?gclid=CJ...FShGagodIyEHtg
http://proformparts.com/mailorder.php
There are many more but you get the idea.
Here's a service that does custom crates for international shipping.
http://www.customcrating.com/?gclid=...FRcjawodWl8eoA
Old 11-15-2009 | 11:04 AM
Saint Ebony's Avatar
Third Generation Moderator
March 2010 ROTM
Old 11-21-2009 | 09:46 AM
draggo144's Avatar
I'm pretty sure the 25th aniv ed had the tbi. You can't just swap a carbed motor in there mainly because of the fuel pump. If you changing from fuel injected to carbuerated you need to put in a different fuel pump. Fuel injected motors run at about 35-45 psi, where carb'ed motors only need 4-6 psi. But as for the motor, a 350 is putting out a lot more power, so you have to make sure your drive train can handle it. The 700r4 transmissions are decent from what I here, but you will probably need at least a shift kit and a higher stall converter. The gears... well, if they bust out, put new ones in lol. The 383, which is what I plan on putting in my 91 z28, will def. put out too much power for your drivetrain.
OurAmericanCars
10-10-2011 03:18 PM
MaVeN
02-14-2011 07:10 PM
RED_CAMARO_V8
06-29-2010 04:25 PM
92 Z28
09-16-2007 09:52 PM
alexval2121
06-19-2007 11:19 PM
Quick Reply: more powerful camaro z28 305 years 1992
