Messy air tubes on my engine?
Ok so I have an 86 305 Z-28 with the 4 bbl carb. Can I remove the air tubes running crazy all over my engine?? Someone went in there and replaced Vacum cannister and a purge vavle? I have no idea what these are but I was told you can remove this system. Inspection is not an issue.
RE: Messy air tubes on my engine?
If you're just talking about the hoses and other stuff related to the AIR pump, then yes you can. There are a lot of other vacuum and heater hoses as well, so know what you're yanking before you do.
It's an emissions item, read this: Air/Smog Pump
The "Changing function" heading pertains to your question.
