Lt1 heads
Old Aug 25, 2009 | 02:09 PM
nextgenrs's Avatar
Default Lt1 heads
search but didnt find much, I found a set of lt1 aluminum heads for 80 bucks, but am wondering if they are compatible with older style 350's, and do they accept the older style carburated manifolds or do they need special ones? Thanks alot
Old Aug 25, 2009 | 02:58 PM
not sure on the fit for the block but the intake is different.
Old Aug 25, 2009 | 03:50 PM
Technically, the LT1 (Gen 2) heads would bolt up to the Gen 1 block. But the water passages are different, and the heads would require some plugging and machining to some of the existing passages to make it work. Then there's the intake manifold. A Gen 1 manifold won't bolt up to the LT1 heads without machine work. Or, the LT1 intake can be drilled and machined to accept a conventional distributor. It's a lot of work, and unless you own your own machine shop, you're going to spend more than a good set of aftermarket aluminum heads would cost.
Old Aug 25, 2009 | 05:19 PM
nextgenrs's Avatar
thanks all i needed to know
fbodyhemi69
LS Series Tech
Dec 7, 2009 05:16 PM
SixShooterCamaro
Oct 30, 2009 08:58 PM
Red Demon
Oct 25, 2007 02:29 PM
1983_JAL
Mar 23, 2007 11:57 PM
