IROC fuel filter help
RE: IROC fuel filter help
Figured it be in an area I didnt look. Thanks! I will check it out in the morning. Do you know if I will need to remove the splash guard or will it be in plain view from under the car?
Also... The Haynes manual states I need to de-pressurize the system. Is this true or just a safety thing that they are saying to cover their butt?
Thanks for the help!!!
Unless you want to spray gas everywhere, (in your eyes, hint hint) you will want to, all you have to do is release the pressure from the schrader valve on the fuel rail.
johnson3034
05-25-2007 09:35 PM
