injectors won't fire
Old Mar 27, 2012 | 03:23 PM
gb1969's Avatar
Default injectors won't fire
i have a 1969 chevelle that I removed wire harness and installed a harness
from a 1990 camaro 5.0 tune port
with computer and steering coulmum
here is the problem
it will crank and i have spark and plenty of fuel preasure
injectors won't fire i have noid lights on them no signal
all fuses are good
i put fuel into the air intake and it comes to life please help
Old Mar 27, 2012 | 09:13 PM
The PCM fires the injectors by putting a ground on one of the injector leads. The 1990 uses batch fire, which means that the ECM fires all the injectors on one bank at once, an then fire the other bank. The ground applied by the ECM is isolated from the chassis ground, but the ECM housing has to be properly grounded to chassis for it to work properly.
mfmfim
Jan 20, 2013 08:28 AM
NEW_CAMARO_OWNER
Aug 11, 2010 05:45 PM
JC316
May 19, 2010 09:36 PM
vray321
Oct 1, 2007 09:23 PM
carguylt1
Nov 5, 2006 03:08 AM
