I'm New and I Heard You Guys Were The Best
Old Sep 30, 2007 | 05:40 PM
I_NEED_A_CAMARO's Avatar
Default I'm New and I Heard You Guys Were The Best
I have a 1985 iroc that has been rebuilt. It has an edelbrock carburetor and air filter. The car stalls out while turning or while on a hill. I think this is because of the floater in the carburetor. I don't think the guy that did the rebuild adjusted it, but just slapped it on. Can anyone tell me if it is the carb and if not then what.
Old Sep 30, 2007 | 07:25 PM
jml317's Avatar
Default RE: I'm New and I Heard You Guys Were The Best
it most likely is the Float. i had a carb that would do sort of the same thing but at full throttle would spray fuel out the carb. i just replaced mine.
Old Sep 30, 2007 | 07:54 PM
MadMikeZ28's Avatar
I would also guess float. But don't expect a definate answer. If cars could be fixed over the web or the telephone there would be no need for repair shops.
Old Sep 30, 2007 | 08:20 PM
Do i need to replace the whole carb or can it be fixed?
Old Sep 30, 2007 | 10:19 PM
Get a rebuild kit for your carb and it should have a new float and needle valve, among other parts, and an instruction sheet telling you where things should be set. That will get you in the ball park, but you still need to do some tuning to get best results. Assuming that the carb is causing your problem.
Old Sep 30, 2007 | 11:54 PM
The only problem is that I have neve worked on a carb. How hard would it be to learn? Is it something thats hard or easy to do?
Old Oct 1, 2007 | 10:45 PM
jml317's Avatar
well it is not the most imposible thing it is relativly simple if u use the sheet with the rebuild that will tell u how to rebuild it.
thetal1
Mar 3, 2010 04:44 PM
tylerparson
Sep 28, 2008 08:58 PM
mombofan1
Nov 5, 2006 02:43 PM
droptop84z28
May 10, 2006 08:10 PM
