Electronic/magnetic speedo?
Old Oct 1, 2007 | 08:36 AM
jml317's Avatar
Default Electronic/magnetic speedo?
Does any one know what year the camaro was switched to a plug type sensor in the transmission for speedometer? i got a new trans for my 1985 but mine was mechanical or gear driven and the new one has a magnetic style? the new trans is not out of a camaro so i had to switch the tail shafts but i think you must take the hole shaft out of the transmission in order to change it to a gear driven.so any imput plz
Old Oct 1, 2007 | 03:11 PM
MadMikeZ28's Avatar
Default RE: Electronic/magnetic speedo?
I think it was in 90 when they changed the cluster. The tailshaft house comes off to change the drive gear. They slip on snug and have a metal retainer/ key.
Old Oct 1, 2007 | 10:44 PM
jml317's Avatar
ok so does the magnetic part come off the other tail shaft? i can get the mechanical one off but not the Magnetic any other suggestions?
Old Oct 1, 2007 | 11:03 PM
MadMikeZ28's Avatar
I thought it came off in the same way. You have to push down on a tab on the metal clip that holds it in place and keeps it from spinning. A tranny guy once loaned me a toolhe had that slipped over the shaft behind the gear and used it like a slide hammer to tap the gear off.
Old Oct 2, 2007 | 12:02 AM
jml317's Avatar
alright thanks well ill try it and see if i can fix it if not im just not gonna have a speedo.
VALHAR
Jul 23, 2011 08:45 PM
YoungDriver
Apr 9, 2009 01:01 PM
stroker383
May 30, 2008 04:29 PM
libertyforall1776
Jun 11, 2007 11:44 PM
davidalvarez82@hotma
LS Series Tech
20
Jan 26, 2007 12:50 AM
