i need a little info
Old Mar 6, 2010 | 03:13 PM
forevverlost's Avatar
Default i need a little info
hi all, i just got an 87 with a 305 4 bbl stock i believe... anyway i cleaned the outside of the carb with carb cleaner and the started it up. it ran fine. so i sprayed a few little squirts in the carb like the can said. i t ended up stalling so i started it back up, at that point i hear a fast clicking sound coming from the carb... still runs fine. sound starts as soon as the key is in the on position.. you dont have to actually try to start it... should i be concerned or is this a normal sound?
Old Mar 7, 2010 | 06:20 PM
microkid's Avatar
March 2011 ROTM
Technical User
can you find the carb model number? if its a computer controlled carb, it could be an adjustment or choke solenoid
Old Mar 8, 2010 | 09:35 AM
where might i find the model number on the carb?
Old Mar 8, 2010 | 07:43 PM
microkid's Avatar
March 2011 ROTM
Technical User
that im not exactly sure on, but its probably on the base or main body of the carb. start cleaning it off and tell us what you find
RodneysPhoto
Mar 28, 2011 01:44 PM
camarogurl843
82-92 V6 Tech
Nov 4, 2010 02:44 PM
Skidoo03
Oct 18, 2010 06:39 PM
Homestar1217
Jun 27, 2009 08:37 PM
vinnyboombots
Apr 4, 2009 03:14 AM
