hesitation
Old Oct 13, 2010 | 12:09 PM
mikecamp88's Avatar
Default hesitation
I have an 1988 IROC 5.7L, car has 38k on it, 800 miles ago the car had wires, plugs, cap, ignition module, fuel injectors and IAC replaced, when the car warmed up hesitates and almost stalls when you accelerate hard from a dead stop, once the car gets going everything is fine, the EGR, fuel pressure MAF, TPS and vacuum have all been checked by the dealer and they say everything is working within specs, any suggestions?
Old Oct 13, 2010 | 01:24 PM
big greg's Avatar
have you checked the timing?
Old Oct 13, 2010 | 02:10 PM
mikecamp88's Avatar
i was told timing was dead on
Old Oct 13, 2010 | 02:23 PM
mikecamp88's Avatar
timing is also advancing properly
Old Oct 13, 2010 | 03:19 PM
97blackcamaroRS's Avatar
test the fuel pressure and change fuel filter? it may be that.
Old Oct 13, 2010 | 03:50 PM
mikecamp88's Avatar
fuel filter was changed when the tuneup was done, fuel pressure in the rail is 43lbs at idle and when driving
Old Oct 13, 2010 | 07:32 PM
any vacuum leaks?
Old Oct 13, 2010 | 08:32 PM
mikecamp88's Avatar
the dealership said there are no vacuum leaks but they didn't smoke the lines, they hook up a gauge to see if the vacuum was in spec.
Old Oct 13, 2010 | 11:25 PM
man idk what else to tell you. maybe try swapping out ur pcm with one of a friend.
cadmanof50s
Aug 1, 2011 10:42 PM
eighty-eight-iroc
Jun 15, 2010 08:01 PM
ryan88z
Mar 26, 2008 10:51 PM
amnesia206
67-69 V8 Tech
Jan 25, 2008 05:06 PM
renee
Aug 12, 2005 11:13 PM
