headers for 305 iroc 1986
Old Oct 12, 2010 | 08:14 PM
1983camaro's Avatar
Default headers for 305 iroc 1986
what have you guys on here found to be the best set of headers for a 305 iroc?
Old Oct 13, 2010 | 01:12 AM
big greg's Avatar
flowtech shorties fit well, cheap too, best is all in perception though
Old Oct 13, 2010 | 09:00 AM
djs383's Avatar
True, plus why headers on the 305? I could see if it just was rebuilt and complete exhaust is in order, but on an existing 305 it seems like a hassle. You'll need collectors to y-pipe welded in, plus if you thought the engine bay was tight before, look out after headers are in, not to mention you'll need to heat wrap all your sensor wires or they'll melt.
Old Oct 14, 2010 | 07:28 PM
microkid's Avatar
March 2011 ROTM
Technical User
im running hedman shorties on my 383 now. i got them and the y-pipe as it was the only header and y-pipe combo without emissions tubes. the only thing that sucks is the y-pipe is 2.5 inch. i just need it now to have it running and will up the size in a year or so, but it would be great for a 305. and you will definatly notice a power increase
btw, the hedmans didnt have the great of fitment though. the metal heater line for the heater core cant stay bolted to the frame rail, and the brake lines and steering shaft are very close on the driver side. definatly needs valve cover removal and jacking up that side the engine will help
Old Oct 14, 2010 | 07:33 PM
big greg's Avatar
i was gonna say i have the headmans and i wouldnt buy a set, they stick out so dang far! they were a pain to install, and come close to everything, i just got mine for a good deal with the y-pipe
Old Oct 14, 2010 | 08:10 PM
Jr. Mechanic's Avatar
August 2009 ROTM
Hedman 68478's are the best budget price headers for our cars. They cost around $330 and are constructed from 14 gauge tubing (most are 16 or 18 gauge) with 3/8" thick flanges (most are 5/16 or 1/4"), and they have a thermal ceramic coating.
The Y pipe can easily be modified with a 3" section rather than the 2.5" section, but it's not worth it on your 305. 68478's with the matching Y pipe modified with a 3" section will support more horsepower than most street 3rd gens will ever have. A lot of people will argue that the 2.25" pipes off the collectors is restrictive, but two 2.25" pipes into a single 3" pipe is a good combination for up to 450-500hp.
Stay away from cheap headers like Flowtech, Jegs, Summit, and low end Hedmans. You will have more headaches than they are worth.
RoyBean
May 31, 2010 07:24 AM
Bob Norris
82-92 V8 Tech
Nov 9, 2007 10:57 PM
blue_iroc_z28
Jul 27, 2007 02:21 PM
smby101
Feb 24, 2007 02:52 PM
