Heads
Old Oct 17, 2006 | 03:45 PM
shnormo's Avatar
Default Heads
What heads would you recomend for a 383 C.I.D. Stroker. I was looking at Dart heads 49cc Combustion chamber and 230 CFM runners. I was also wondering what's the highest compresion ratio I can run on 104 Octane? WIth that combustion chamber, felpro gaskets, and the pistons I'm using, I have a 14.3:1 ratio. I got the rotating assembly so it all depends on the heads now.
Old Oct 17, 2006 | 05:29 PM
Default RE: Heads
Which engine are you dealing with. Standard small block, new LT1 type?
Old Oct 18, 2006 | 02:40 PM
shnormo's Avatar
Default RE: Heads
Standard Small Block
Old Oct 18, 2006 | 03:57 PM
Default RE: Heads
We had a car years ago with similiar compression, and had to use 120 octane aviation fuel to keep it from detonating and still use a proper spark advance. Aluminum heads may help the situation, and if you were were using an LT1 with its reverse cooling it may help even more. You can also go to 110=112 octane racing fuel, and the price difference is not that much.
Old Oct 18, 2006 | 04:03 PM
shnormo's Avatar
Default RE: Heads
Think I should open the combustion chamber more (as in choosing a different head) prolly a 54 CC?
Old Oct 18, 2006 | 04:22 PM
Default RE: Heads
If you stay below 13:1, it will definetely make tuning easier.
Old Oct 18, 2006 | 05:38 PM
shnormo's Avatar
Default RE: Heads
Thanks
fbodyhemi69
LS Series Tech
Dec 7, 2009 05:16 PM
SixShooterCamaro
Oct 30, 2009 08:58 PM
Red Demon
Oct 25, 2007 02:29 PM
1983_JAL
Mar 23, 2007 11:57 PM
