hard steering
Old May 24, 2009 | 04:09 PM
duece's Avatar
Default hard steering
I have a 91 RS convertible that I just finished restoring and I have one issue. the power steering is really hard. I did take the steering box apart and look inside, but I don't remember taking anything apart, might have moved a couple things. Anyway, The P/S pump is new and seems to be working. didn't notice any issues with steering column when I brought it home, but I suppose something could have happened since then.
thanks
Jim
Old May 24, 2009 | 09:27 PM
mighty mike's Avatar
could be air bubbles in the lines
Old May 24, 2009 | 09:58 PM
Was the steering hard before you opened up the steering box, or only after?
If there's air in the system, it will bleed itself after you go through a couple of lock-to-lock cycles.
Old Jun 2, 2009 | 04:37 PM
duece's Avatar
Thanks for the info, but it isn't that is steers that hard, but the wheel won't return while driving. Example, when you turn a corner the steering wheel stays in that position and won't come back like others do.
Old Jun 2, 2009 | 04:45 PM
duece's Avatar
One other bit of info..when I do hit the stops the pump doesn't squeel or make any noise at all.
Old Jun 2, 2009 | 05:50 PM
If your steering doesn't feel stiff, then your front end is probably out of alignment. Primarily, the "caster" would be the issue. Caster is the angle at which the upper and lower pivot points of the steering are tilted, if you were to draw a vertical line through the upper and lower ball joints (or upper strut mount in your case). Positive caster tilts the angle back at the top pivot point which keeps the car tracking straight down the road, and is also what straightens the front wheels back out after a turn.
Old Jul 2, 2009 | 06:31 PM
Mesosneaky's Avatar
wow man your awsome lol.
sl1foru
Feb 20, 2008 06:41 AM
sicked_wick
Aug 12, 2007 10:34 PM
sicked_wick
Jul 23, 2007 12:51 PM
sicked_wick
Jul 21, 2007 01:29 PM
ashish108
Jul 12, 2007 04:52 PM
