Hard Steering Wheel
Old Jul 11, 2007 | 10:10 PM
ashish108's Avatar
Default Hard Steering Wheel
I have a V6 with just 34K miles. Is there a reason why the power steering is so hard to use?When I jack the front of the car and start the car, the steering is quite easy to turn. So is it just the weight of the car? Or was it just designed like that? Do other folks experience the same?
Thanks.
Old Jul 11, 2007 | 10:14 PM
libertyforall1776's Avatar
Default RE: Hard Steering Wheel
Maybe your fluid is low, or your pump is on the outs?
Old Jul 11, 2007 | 10:22 PM
ashish108's Avatar
Is there something like performance steering pump available for this car? If I replace it, I might as well usehigh performance pump.
Old Jul 12, 2007 | 12:13 PM
badinfluenceRS's Avatar
Pumps are the same, no high perf pumps and it sounds like your pump is bad...it's a quick, cheap and easy fix.
However, if your looking for tighter steering, you could swap a gearbox out of a Z28 or a V6 Y87 car for the sport steering ratio...but pumps are all the same perf level, doesnt' really matter
Old Jul 12, 2007 | 12:26 PM
bluovlh8er's Avatar
bad... is there a huge difference between the two?
Old Jul 12, 2007 | 01:01 PM
I haven't driven another 3.8 V6 that does not have the 14.4:1 Sport Steering, but I drove a 94 3.4 that was alot "looser" than my 96...
I cant seem to find the base V6 steering ratio to compare the difference tho
Old Jul 12, 2007 | 01:03 PM
bluovlh8er's Avatar
ooo... i was about to upgrade my stearing box.
Old Jul 12, 2007 | 01:44 PM
Don't you have a Y87?
If so then you already have the best factory gearbox...same as a Z
Old Jul 12, 2007 | 01:47 PM
bluovlh8er's Avatar
naw just a plain old regular RS with 3.08's [:@]
Old Jul 12, 2007 | 04:44 PM
ashish108's Avatar
If I flush out the old steering fluid, maybe the new fluid will have better hydraulic properties than the factory stuff.
