gettin hot!!
Old Jun 28, 2008 | 02:40 PM
vabeachxj's Avatar
Default gettin hot!!
ok we just got done rebuilding the top end of my 89 rs when we went to turn it over it don't want to start and the grounds are getting way hot i don't know if i am missing something but i can't find any wires i missed hookin back up but i think there was 2 or 3 wires on the drivers side ground but i can't rem and i only have 1 hooke d up any help would be nice
thanks
Old Jun 28, 2008 | 03:14 PM
MadMikeZ28's Avatar
Default RE: gettin hot!!
you have the ground on the back of the head to the firewall? Then there is the main battery ground which should go some where to the engine (depends on what year where but as long as its on there its good) and a 10 gauge to the chassis
Old Jun 28, 2008 | 05:39 PM
vabeachxj's Avatar
ya we didn't mess with the battery ground or the one to the chassis all we pulled off was the 2 going from the heads to the firewall
Old Jun 29, 2008 | 11:31 AM
Based on your post I would guess the valves are too tight and the starter is not strong enough to turn the engine over. Did you replace the valve springs? Might want to check theygave you the right ones. Back the valves off and see how it cranks. You need to test your starter draw to see if its within spec.
Of course there are a lot of other things that it could be. Even the fact the carsat for a few day could have let a connection that was starting to go bad to get bad enough to effect the starting.
Old Jun 29, 2008 | 12:50 PM
vabeachxj's Avatar
we did not replace the valves they all looked good very min wear we are gona run a comp test tomm and prob reajust the rockers to make sure we did not over tighten them
thetal1
Mar 6, 2010 08:01 PM
jnghall
Nov 14, 2009 05:04 PM
v8burninator
82-92 V8 Tech
Jan 26, 2008 06:12 PM
6v49der
Jun 30, 2007 11:51 PM
