gasket leak ???
Old Apr 10, 2007 | 06:07 AM
coppercar's Avatar
Default gasket leak ???
I have a 95 camaro z28 auto. and my car can't go 10min with out gradually getting too hot. if I don't shut it off at that point it will go into red. I took it to a guy who said it was a head gasket leak. I hwant to make sure before I put in all the work. and I'm on a really short budget right know. how could I make sure that's the problem. Under the hood the car isn't even really hot and it sounds healthier than ever. if it weren't for the gauge you wouldn't even know theres a problem. Any help is much apriciated. Thanks.
Old Apr 10, 2007 | 01:05 PM
Izzy's Avatar
Default RE: gasket leak ???
Are you leaking oil anywhere?
Old Apr 10, 2007 | 01:16 PM
74454bb's Avatar
May 2007 ROTM
have you checked your thermistat, and coolent level?
Old Apr 10, 2007 | 01:49 PM
94Z28SHAKER's Avatar
sounds like your thermostat might be bad, like 74454 said, if the thermostat doesnt open it will just build up pressure and get hot.
Old Apr 10, 2007 | 01:54 PM
dont your fans turn on when it gets almost to the 75% hot?
Old Apr 10, 2007 | 03:25 PM
You can have the coolant tested for combustion gases, and you will know for sure if you have a gasket leak. However, if you are overheating that fast, it could be a head gasket, especially if there is a lot of steam coming out of the exhaust when the engine is hot.
Old Jun 28, 2009 | 10:54 PM
keokabear's Avatar
I just pressure tested for my gasket today. Get a pressure tester, most auto parts stores loan them. ( i like o'riellys). With the car cold, put the tester on your radiator. Don't pump it up. Start your car. If the presure jumps pretty high in the first 30 secs or so, odds are your gasket is leaking. Unfortunately mine is fine, so my problem is still a mystery, but maybe you'll get lucky.
Old Jun 28, 2009 | 10:55 PM
keokabear's Avatar
Default how to pressure tet your gasket
mccoyj91
Dec 21, 2010 08:20 AM
g3mini609
Dec 26, 2009 06:21 AM
Vandee
Nov 19, 2009 07:04 PM
pimpdd101
May 17, 2008 09:05 PM
Sevenpelicans
Dec 6, 2007 11:07 AM
