fuel pressure at filter ?
I am going to make a adapter so that I can check the fuel pressure at the filter. I am trying to fgure if my pump is bad or the regulator is faulty. My question is what is a rough number of what the pressure should be before it is regulated? I forgot to add it is a 305 tpi
RE: fuel pressure at filter ?
I wish it was I tested the pressure at the fuel rails and it was 10psi so I thought it was a bad pump ,but the more I thought about it the more I thought it could possibly be the regulator so I fabbed up a fitting to conect my gauge to the filter. In the end I figured out the problem was the pump I got the same reading at the filter 10psi.
royco95
08-02-2015 10:25 AM
BoricuaHec01
LS Series Tech
03-17-2011 05:56 PM
johnson3034
05-25-2007 09:35 PM
