Do fuel pumps constantly run so loud?
Old Aug 25, 2008 | 08:07 PM
Hfourx's Avatar
Default Do fuel pumps constantly run so loud?
I feel dumb for asking, but here goes.
On my 1992 camaro, when you put the key forward you hear the fuel pump for 2 seconds and its pretty loud.
Does it run all the time? and is it normal for it to be so loud?
Thanks in advance
-Hfourx
Old Aug 25, 2008 | 08:55 PM
Default RE: Do fuel pumps constantly run so loud?
How loud is loud? It normally makes a noticable noise for the initial prime when you turn the key on. And no, it doesn't keep running after that. It won't run again until you start the engine, or if you turn the key off and on again. BTW, your pump will be noisier if your fuel in the tank is low.
Old Aug 25, 2008 | 09:22 PM
Hfourx's Avatar
Yeah, im getting the initial prime but it still sounds like its running when im driving the car for some reason. Any ideas?
Old Aug 26, 2008 | 12:09 AM
I thought I explained it correctly...maybe not?
The pump is supposed to be running when the engine is running. But you shouldn't really be able to hear it, unless you go listening for it in back. Your pump motor is probably on it's way out. Or, could just be your exhaust isn't loud enough!
jimm418
Jun 20, 2014 11:03 PM
shawnathan
LS Series Tech
Sep 5, 2012 06:55 AM
Emma111
Jul 7, 2011 06:08 AM
jsmooth1988
Nov 26, 2008 12:44 PM
lantzdarla
Apr 11, 2006 08:51 PM
