do 305tpi, and 350tpi have same computer
Old Jan 1, 2011 | 08:08 PM
czaj1992z28camaro's Avatar
Default do 305tpi, and 350tpi have same computer
hi, recently bought a 1992 z28 camaro. previous owner swapped the 305tpi with a 350tpi. he used all the same wiring for the swap. do the 305, 350 have the same type of computer? or would i need to switch it out? just starting out on the car thing, so dont know very much at this time. thanks for your time.
Old Jan 1, 2011 | 08:13 PM
blackz87's Avatar
Uses the same ECM except for the prom and he may have changed that. How dose it run???
Old Jan 1, 2011 | 09:06 PM
it runs very rough when first started. have to let it warm up awhile before i shift into drive or it just clonks out. when i do get going its seems very hesitant, then after about 15 minutes it usually runs great then. replaced fuel pump, sending unit. not sure if it could of been the computer, or maybe it needs a new ignition.
Old Jan 1, 2011 | 11:51 PM
Caveman305's Avatar
as stated above, same computer, different prom(chip), if you want to verify its the right chip, unscrew the cover on the ECM, there should be a sticker on the chip that has 4 letters on it, find out what that says and it will tell you if you need to swap the chip
wsmikey
Apr 4, 2010 08:16 PM
yamban
Jan 25, 2009 01:22 PM
irocktheIROC
82-92 V8 Tech
Mar 30, 2008 12:42 AM
SS5150
May 19, 2007 08:38 PM
