dipping rpms and voltage
Old Jun 25, 2007 | 09:29 PM
350badass's Avatar
Default dipping rpms and voltage
alright this car is working perfectly except for this issue...ive tried everything i can think of so if anyone has an idea please help. its a TBI 92 rs camaro, was a 305 now its a 350. its completely stock 350 except for the headers and exhaust. for some reason the car when driving and idoling will have dipps in the RPM's and also in the voltage and eventually will stall the carwill stall out. i supected a loose ground somewhere but cant seem to find one. im getting a number of codes from the computer but if they were all really problems this car wouldnt be running. i have list of the codes but they arent with me ill post them and what they stand for shortly...im at the end of my rope here. please help. thanks in advance!
-seth
Old Jun 27, 2007 | 10:33 AM
microkid's Avatar
March 2011 ROTM
Technical User
Default RE: dipping rpms and voltage
what rpm is it idling at? how many amps is the alternator? my old alternator used to only run at 13 volts once the car was running for a while, until the voltage regulator went bad. now it runs between 14-14.5 volts. whats your voltage reading?
Old Jul 25, 2007 | 11:06 PM
Auji350's Avatar
Yeah check you're altonator.. I just had one go
Old Jul 26, 2007 | 05:20 PM
parker987654321's Avatar
check the ground on the back of the engine that bolts to the body if it is rusty clean it it. also check the TPS and the rotor in the distributer alot of times it might not make a good connection and that will make the car almost want to stall which you can not get good voltage if the car is not running right.
Old Aug 24, 2007 | 02:43 AM
350badass's Avatar
ok well the altenator runs at about 14 t0 14.5 volts but dips when i accelerate. ground on the back of the head is good and i havent had a chance to check my distributer...thanks alot for the help so far guys ill kep you updated
[align=left] [/align]
Old Sep 1, 2007 | 01:20 AM
89rscamaro's Avatar
make sure the power and ground are tight on the battery too, that could also do it. it happened to my camaro when i added an amp wite the stud was too long.
onebad88
Sep 18, 2012 11:06 AM
Jerry95lt1
May 3, 2011 05:59 PM
SSPOWER
Nov 26, 2007 04:55 PM
CRanMaro99
Oct 14, 2007 08:36 PM
squisher
Feb 9, 2007 09:42 AM
