LT1/LT4 Tech 1993-1997
low voltage
Old Apr 29, 2011 | 04:52 PM
Jerry95lt1's Avatar
Default low voltage
my 95 z28 has low voltage. what would cause this problem? its always touching the red.
i already tested it with another battery and it didn't get better voltage.
Old Apr 29, 2011 | 04:53 PM
BasicConcepts's Avatar
Technical User
alternator
Old Apr 29, 2011 | 05:09 PM
Jerry95lt1's Avatar
alternator
i dont think so. its a brand new alternator. i installed about 2 months ago. any other ideas. thanks.
Old Apr 29, 2011 | 06:08 PM
Grandpaswagon's Avatar
Check your voltage at the battery with the engine running. It should be around 14.5 volts (DC). If that is good, then you probably have a faulty voltage gauge. If it is low, start by checking the +12 VDC junction on the passenger wheel well near the battery for any corrosion.
Also check your grounds for any corrosion or loose connections.
If all of the above checks out, you could still have a bad alternator (even though it is new). Take it to the parts store and have it checked out.
Old May 3, 2011 | 05:59 PM
Psycho's Avatar
Are you saying that the gauge on the car is always reading low?
If the alternator checks out good and the battery does too then the gauge is bad. Of course bad grounds can be the source of alot of electrical problems.
onebad88
Sep 18, 2012 11:06 AM
Grandpaswagon
May 8, 2010 10:21 AM
CRanMaro99
Oct 14, 2007 08:36 PM
squisher
Feb 9, 2007 09:42 AM
350rs
Aug 27, 2006 05:23 PM
